Rings not seating?
Re: Rings not seating?
Originally Posted by med_reject
I guess evidence based medicine is totally different from engines then. We are always evaluating and re-evaluating research and modifying treatment guidelines accordingly.
Originally Posted by 1racerdude
If ya have a research treatment that is not proven to work yet,and this is a life or death,do you go with what is known to work or the unproven one??
Originally Posted by Warlock1313
I guess the car doesn't burn oil anymore if this is debate now
Back on topic, 'MEAN LT1' might consider putting dyno oil back in temporarily, and try a 'last ditch effort' to get the rings to seal. By LDE, I am implying a technique used by Smokey in the 60s, to get a running engine to seal quick for an impending race. It was effective without any negatives that I am aware of. Any oldtimer here, aware of this technique? Hint to others; it was poured down the carb, but wasn't wet.
I was referring to a household cleaning product (powder) known as Bon Ami. Although not shown to be harmful to an engine, I would use it as a final attempt at sealing an engine, and not the first course of action.If you have decided to pull the engine, this would make for a great opportunity to try it. If it isn't effective, no loss. If it does the trick....
Formula Steve
Sep 19, 2023 08:31 AM
