Rim Locks?
Old Oct 1, 2004 | 10:08 PM
ChrisUlrich's Avatar
Rim Locks?
When I bought the car, I really didn't check this little detail. I can't find the rim lock for the lug nuts!! How am I going to undo this?!
Old Oct 1, 2004 | 10:24 PM
GreenDemon's Avatar
Re: Rim Locks?
I know someone makes some sort of socket specifically for getting those off without the key. Do you still have that paper with the serial # on it? You could have a new one sent to you.
Other methods aren't so pretty. You can try banging a slightly oversize socket on and using an impact wrench to get them off, but you might destroy sockets, or you can use a cutoff wheel and just go through them- just don't go through the studs...
Old Oct 1, 2004 | 10:35 PM
97WS6SCharged's Avatar
Re: Rim Locks?
Or go to a dealership. They usually have keys and will remove the lugs for a small fee. I'm assuming you're talking about the stock lug nuts though.
Old Oct 1, 2004 | 11:57 PM
Z95m6's Avatar
Re: Rim Locks?
I suggest trying for a couple hrs to remove them with vice grips which will be pretty much like pissing into the wind. Then i would go get my Summit catolog and order the special socket they have to remove locking lug nuts with out a key.
Old Oct 2, 2004 | 12:52 AM
mojorisin's Avatar
Re: Rim Locks?
just use a cheap socket and beat it on the lug nut with a hammer, but dont expect to get it back off. it does work, if you have 4 sockets to spare
G-BODYT56
Jan 14, 2022 11:14 PM
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
