Is this the right size crank/hub bolt?
Old Feb 25, 2007 | 09:58 PM
FireFox5.0's Avatar
The crank/dampener bolt stripped, Is this the right bolt?
http://store.summitracing.com/partde...1&autoview=sku
Old Feb 25, 2007 | 10:01 PM
mdacton's Avatar
should work...thread is right but measure the length. I have ATI damper .....not sure what the stock bolt lenght is
Old Feb 25, 2007 | 10:10 PM
seawolf06's Avatar
That's the one that Thunder sold me. I'll double check tomorrow to make sure it fits right. Only difference seems to be the size of the head.
Old Feb 25, 2007 | 10:35 PM
Stock bolt is 7/16-20 x 2-1/4. Stock head size is 5/8".
Old Feb 25, 2007 | 11:29 PM
FireFox5.0's Avatar
Thanks. The only difference between those two is the bolt head size, one is 5/8ths and the other is 13/16, and about $2.
Old Feb 25, 2007 | 11:33 PM
seawolf06's Avatar
You know you never can get enough head.
I'd recommend the first one since mine didn't quite fit inside the stock hub.
Old Feb 26, 2007 | 08:58 PM
FireFox5.0's Avatar
The one with the 5/8ths head worked great. It was tight, must need a thinwall socket for the 13/16ths. I am so glad the tap cleaned out the crank.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
