Is this the right cable to get my pcm tuned by pcmforless??
Cable with molded OBDI Connector, approx. 15 ft. in length
Recommended for use with LT1_Edit Software, TTS Datamaster, and other high performance communications software (go to my order form) $95.00
If so then is all i have to do is buy these then pay him and tell him what i need and i can download that on my laptop and hook it up to my car and then it programs it is that the general idea?? I'm kinda lost by i have to do my tuning over the net b/c its my daily driver and theres not to many dyno tunes around here well tell me what u think
Yes, that is the right connector. You have a OBDI PCM pin connectors(12 pin) with OBDI connector(black plastice pice). 95's had OBDI pin connectors (same PCM) but OBDII shaped connector. All 96-present have OBDII pin connecotrs(16 pin) with OBDII connecotr. As far as the uploading, ask Bryan for the Windows version of the flash software. You'll have less problems and likelyhood of erasing your PCM. I have been using and loading Bryan's programs for almost 2 years now with no real problems. If you have any questions, feel free to ask,
Kyle
Kyle
DSMKilla
May 26, 2015 10:10 PM
turbo_Z
Aug 19, 2002 10:50 PM
