reverse lockout solenoid
The solenoid is located directly to the left of the shifter. If you take your console off you can see it sitting to the left. There is some way to test it by applying a 12v current to one of the wires but I'm not sure which one. If you get one of those cheapo Haynes manuals at Autozone or Discount Auto it tells you how to do it because I was going to test mine once. I just had to have mine replaced yesterday.
Re: reverse lockout solenoid
Originally posted by ollie-99
how can i check if it still works
Dave
Unless for some odd reason, the pcm is continously grounding the solenoid to keep it engaged, then yes.
Off hand, I would have to say it's not possible to take the unit apart w/out pulling the trans., BUT I could be wrong. However the unit is very basic and easy to disassemble.
Dave
Dave
I just got mine replaced for $115 for the part from a dealer, so you could probably find one for cheaper if yours is broken. Mine was going into reverse if you weren't careful and now it's 100% better.
RUENUF
Mar 13, 2016 03:37 PM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
