Reverse flow cooling question. LT1
Old Aug 1, 2006 | 12:22 PM
fast 93 z's Avatar
On an LT1 the lower drivers side waterpump outlet that has a hose that runs to the bottom of the radiator. Can this be plugged or does this hose have something to do with the reverse flow cooling. My glimer vaccum pump belt will be hitting this nipple and I would like to pull the nipple out and plug the hole. Has anyone done this before? What is the purpose of that hose? I honestly have no idea.
Tony
Old Aug 1, 2006 | 01:25 PM
Sparkz28ss's Avatar
Re: Reverse flow cooling question. LT1
the one sticking out pointing to 9 oclock?
http://www.justcorvettes.com/NewImag...or%20front.JPG
Old Aug 1, 2006 | 02:36 PM
96TurboTA's Avatar
Tony
That connection is for cars equipped with an oil cooler.
Old Aug 1, 2006 | 02:37 PM
96TurboTA's Avatar
That's a vette waterpump. It doesn't have the connection on the driverside like the fbody pump.
Old Aug 1, 2006 | 03:51 PM
fast 93 z's Avatar
No.......I dont see it in that pic. It is at like 3:00. Looks like it is just a provision for the cooler. Some had coolers and some did not. I am going to plug it!!
Thanks guys!
Old Aug 1, 2006 | 07:13 PM
96TurboTA's Avatar
Thanks guys!
No problem. I just picked up a new waterpump for my 96TA this evening. After looking at it, blocking off that port won't cause any problem that I can see.
Old Aug 1, 2006 | 08:31 PM
Kevin Blown 95 TA's Avatar
Let us know how that goes. I wondered the same exact thing myself, but left it in there.
Old Aug 3, 2006 | 09:34 PM
edholio's Avatar
I've run it blocked for 9 years and never had an issue. Just capped it and the corresponding radiator connection.
Old Aug 3, 2006 | 09:54 PM
Thanks, that would be one less hose in my way... Next time it's apart, that's coming out.
Old Aug 7, 2006 | 10:11 PM
busta9876's Avatar
I've always plugged it on my LT1 swaps i've done, however, I did find it usefull for filling a dry engine with coolant.
Old Aug 8, 2006 | 09:27 AM
fast 93 z's Avatar
What about the other two heater hose connections on the other side of the waterpump? Has anyone ever plugged those? I have them looped together but would like to plug them as well.
Old Aug 8, 2006 | 10:27 AM
thesoundandthefury's Avatar
I welded mine shut:
You can save yourself a little bit of hassle in that area if you buy a 92 Corvette model water pump. They came from the factory originally equipped with only the one upper heater hose barb.
Old Aug 8, 2006 | 10:42 AM
fast 93 z's Avatar
Very nice! Did you polish that? Thanks for the info. I will plug them as well. I do have an extra Corvette water pump in storage. I wish I would have used that one but I already have this one powdercoated.
HectorM52
Jun 23, 2016 08:42 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
