reverse cooling?
Old Mar 9, 2007 | 09:10 AM
  #16
Z-RATED94's Avatar
Originally Posted by 93redbird
Its just a different pressure cap... thats all
From what I can remember, I'm pretty sure 93redbird is correct.
Old Mar 11, 2007 | 05:59 PM
  #17
Spllouder's Avatar
Originally Posted by LiENUS
Bearings missing == bum water pump (In the eyes of the engineers who designed it), the cam driven water pump decision was made because it was supposed to put less load on the water pump bearings. the seal being shot is evidence of poorly maintained cooling system although once again if its a bum water pump the seal can go prematurely, 65,000 miles is a lot of miles for a water pump, but they were supposed to last more than 100k...
I meant the bearing seals were missing or destroyed and some ball bearing were missing .
Old Mar 11, 2007 | 07:06 PM
  #18
LiENUS's Avatar
Yes, the bearing failed because it was a bum water pump, they are supposed to last 100k+ miles and when they don't unless its related to poor maintenance I regard it as a bum water pump.
Old Mar 12, 2007 | 01:03 PM
  #19
Casey_SS's Avatar
Probably not much value in saying this, but the factory pump in my '97 is still going strong at almost 130k...I've learned that part failures in these cars are tough to predict. If you talk to enough folks you'll find that it's like anything else - some last forever, some don't.
Hell, my stock Opti is still doing great....according to most people on here half the parts on my car should've died a long time ago.
Just the luck of the draw I guess...when I think about though, it's kinda funny - if GM's failure data shows say a 10% failure rate for WPs, Optis, etc., I bet most of that 10% has posted about it on an internet forum somewhere
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
