rev limiter help with pcm
Old Jul 1, 2009 | 11:08 AM
rock1501's Avatar
I just want to view what the limiter is set at in the pcm(obd1)
I have it set at 7500 on the msd but just about 100ft from the traps at about 7000 rpm I hit the limiter.Any way to view what it is set at with a free program?
I have a laptop and the cable already
Old Jul 1, 2009 | 03:18 PM
rock1501's Avatar
strange I was able to look at the fuel cutoff settings in tunercat and they are set at 9074 rpm yet I am hitting some sort of rev limit at around 7000 rpm
Old Jul 1, 2009 | 03:27 PM
Stl94LT1's Avatar
The stock PCM tops out at 7k rpms, at least the timing and PE tables. But, I have heard some have found a way to tune around that level.
Old Jul 1, 2009 | 03:39 PM
96capricemgr's Avatar
My understanding is if you try a handful of PCMs you might find one that will let you have another 1-200rpms that is it though the pcm HARDWARE can't handle any more.
Old Jul 1, 2009 | 04:42 PM
rock1501's Avatar
thanks
I guess its time for some 28 inch tires or BS3
KYWes
Jun 14, 2022 06:52 AM
Boss002
Jan 20, 2016 12:17 PM
asilomar244
Jul 12, 2015 05:53 AM
surreybrad
Jul 5, 2015 10:36 PM
cristian1311
Apr 22, 2015 10:20 PM
