rev limiter?
Old Feb 23, 2006 | 05:27 PM
yzblue125's Avatar
rev limiter?
hey guys quick question, i was driving today and got down on her full throttle and when it hit the red line to shift the rpms started jumping all around, they would fall a couple of hundred than rev back up,seems like the rev limiter but i have never had this problem before, it usually shifts out. any ideas?
Old Feb 23, 2006 | 06:49 PM
plattted's Avatar
Re: rev limiter?
Some one should talk about this so-called-rev limiter! Could it be just a lack of fuel or valve float? Or-perhaps just ignition failure-what do you think? 93ZTED
Old Feb 23, 2006 | 07:04 PM
LiENUS's Avatar
Re: rev limiter?
Fuel cutoff pretty standard on any car with efi.
Old Feb 23, 2006 | 07:16 PM
FastLt1's Avatar
Re: rev limiter?
You need to get it reprogrammed for the high stall and the shift kit. Trust me. Something about the transgo shift kit and high stall. PCMforLess can hook you up. Be sure to let them know about the shifting problem.
Old Feb 23, 2006 | 08:12 PM
yzblue125's Avatar
Re: rev limiter?
whats so weird is that its never done this before, and ive dogged on her plenty of times, why would it just start if it was something thats been there all along like a rev limiter.
Old Feb 23, 2006 | 08:14 PM
FastLt1's Avatar
Re: rev limiter?
Or trans could be starting to slip.
Old Feb 23, 2006 | 08:25 PM
GreenDemon's Avatar
Re: rev limiter?
Sounds fuel or ignition related to me. Usually the rev limiter is pretty consistent- I've hit mine a few times- "ding-ding-ding!"- you get the idea. Your coil could be crapping out, your optispark could be having problems (I had this one, at high rpms the tach would start swinging wildly, I'd have to let off the gas to get it to shift sometimes ), or your fuel pressure could be dropping off. I suppose valve float could be a problem too, but it's not something I'd think of first. I'm sure there's other things too, I can't remember them all. BTW, problems like these are a pita without good diagnostic equipment (unless it gets worse and the car won't even run, anyway).
Old Feb 23, 2006 | 10:48 PM
T/A Racer's Avatar
Re: rev limiter?
im wondering about the tranny starting to slip too thats why its hittin the rev limiter
Old Mar 31, 2011 | 05:47 PM
dirtybird81's Avatar
Re: rev limiter?
revisited this thread a few moments ago looking into a high rpm miss or "rev limiter" around 5700 to 6000 rpm found absolutely nothing helpful especially when these guys started talking about shift kits and stalls and trans slipping im pretty sure in the sig. it says he has a m6 right? wtf
Old Apr 1, 2011 | 05:29 AM
Re: rev limiter?
Are you having a similar problem and need help, or are you just pulling up a 5 year old thread so you can criticize?
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
