Rev Limiter???
Rev Limiter???
Quick question about the rev limiter. Does anyone know if there would be any problems if i would have the rev limiter removed from the computer. If there would be could any one tell me what kinds of problems i would expect . I was just curious what would happen if i do program it out. Advice is greatly appreciated.. Thanks..
Re: Rev Limiter???
You can't remove it. You can only change it. I believe the stock PCM can only go to 7k rpm's. If you want to go higher you will need an aftermarket PCM. Also, unless you have a modified valvetrain, you don't need to go higher than stock.
Re: Rev Limiter???
thanks... i was just curious what would happen im not going to do that.. i began hitting the stock rev limiter after i had my 3.73s installed and at WOT it hits the rev limiter and i have to let off the gas and hit it again for it to shift into the next gear. Bryan at pcmforless says its fixable... so i will just have him straighten the rev limiter out..
Sep 11, 2015 09:44 AM
