rev limit?
Old Aug 19, 2005 | 11:37 PM
fasteddie94's Avatar
rev limit?
My Crane ignition arrived today and i was wondering what the rev limiter should be set to. It's already at 5500 but I think that soumds a little low.
Old Aug 19, 2005 | 11:39 PM
jerminator96's Avatar
Re: rev limit?
Your PCM should have a stock rev limiter programmed in, If i'm not mistaken that has to be reprogrammed before you can set a higher limit.
Old Aug 19, 2005 | 11:52 PM
madwolf's Avatar
Re: rev limit?
That is correct.
Old Aug 20, 2005 | 12:00 AM
Re: rev limit?
Would the limiter in the box override if it is lower than the one on the pcm or can i just leave it alone?
Old Aug 20, 2005 | 04:23 PM
Re: rev limit?
The lower of the 2 limits will work first, if it is a stock motor then you have no real reason to raise the rev limit, its there for a reason.
Old Aug 20, 2005 | 09:23 PM
Re: rev limit?
What's the stock limit? I am just trying to figure out where to set the one on the ignition box, I don't plan on raising the limiter on the PCM.
Old Aug 20, 2005 | 10:53 PM
hellostop's Avatar
Re: rev limit?
my 94 is 5800 or 5850.
Old Aug 20, 2005 | 11:12 PM
Cmr0z28's Avatar
Re: rev limit?
Stock LT1 rev limiter is 5800.
Old Aug 21, 2005 | 04:11 AM
kgkern01's Avatar
Re: rev limit?
Actually its 5750 to be technical.
Old Aug 21, 2005 | 10:44 PM
Re: rev limit?
Thanks guys. I am almost way too lazy to look that up. Do any of you guys know of a site to referance general specs like that?
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
