reusing bolts '97 LT1
Old Jan 27, 2004 | 03:35 PM
simple's Avatar
what bolts can be reused?
which should i get new?
i have new ARP headbolts.....curious about what else can be reused when doing a head and cam swap?
thanks
Steve
Old Jan 27, 2004 | 03:48 PM
Red_94Formula's Avatar
Its good to use new head bolts. All other bolts can be reused.
Old Jan 27, 2004 | 04:21 PM
simple's Avatar
what about the balancer crank pulley bolts?
intake manifold bolts can be reused?
all the cam bolts too?
Steve
Old Jan 27, 2004 | 07:01 PM
Steve
Generally ok to reuse those, just make sure you follow torquing procedures. If you are concerned about the bolts, replace them.
Old Jan 27, 2004 | 07:36 PM
Don 97 SS's Avatar
I agree with your approach.
Old Jan 27, 2004 | 08:31 PM
Josh-'04 GTO's Avatar
Not exactly sure how much work you're doing, but main, rod, and head bolts should all be ARPs with no questions asked. The other stuff you mentioned can reuse factory bolts without a problem.
Old Jan 28, 2004 | 03:40 AM
simple's Avatar
thanks guys! just wanting to be 100% clear on what i can reuse!!
Steve
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
