Retainers and Locks for Beehive Springs
Old Feb 27, 2007 | 03:22 PM
buzz12586's Avatar
Which part numbers do I need for the retainers and locks that fit the 918 Beehive springs??
Old Feb 27, 2007 | 05:47 PM
truedualws6's Avatar
Assuming you have stock LT1 heads
Here it is again for the 100th time.............
If you want to go with 7 degree hardwarde:
787-16 retainers
648-16 locks
stock or LT4 spring seats
If you want to go with 10 degree hardware (super locks):
795-16 steel retainers, or
794-16 titanium retainers
611-16 locks (standard), or
614-16 locks (+.050)
4705-16 spring seats
Using the 7 degree hardware and stock spring seats you
should end up with an installed height close to 1.78". With
10 degree hardware, 4705-16 spring seats, and the +.050
super locks you should see a 1.75" installed height.
Many have used the stock or LT4 spring seats with these
springs. I personally don't like the way the springs sit on the
spring seat. I have the 10 degree setup on mine.
Old Feb 27, 2007 | 07:47 PM
SStrokerAce's Avatar
I always recomend the 4705-16 spring seats.
Bret
Old Feb 27, 2007 | 09:52 PM
buzz12586's Avatar
Sorry, I searched for it and I saw posts about the 10 degree hardware but I never saw any comp part numbers. Thanks for the help.
Old Mar 16, 2007 | 10:11 AM
jclt12003's Avatar
can someone please explain this to me as i'm kinda of a noob to the retainers and seat things. I'm in the process of installing a GM847 and am using the 918 springs as well. What does the degree mean changing it from 7 to 10, is there any advantages or disadvantages.
Jason
Old Mar 16, 2007 | 12:01 PM
7/10 degree locks
The main difference is strength. The Comp super locks are 10* whereas
the stock locks (both Comp, GM and others) are 7*. You need to look at
them side by side and it will be obvious why they are stronger. The main
reason to use the Comp 10* super locks is that they are available in +.050"
which helps achieve a taller installed height when you use the 4705-16 seats.
For most stock or mild performance engines the 7* locks are just fine. If
you are planning on using beehive springs I suggest you do not use the
stock spring seats. This is where the +.050" super locks come in handy.
Old Mar 16, 2007 | 07:06 PM
jclt12003's Avatar
What spring seats should I use with the 918 springs. Can i get a link to the ones everyone else is running thanks for all the info.
Jason
Old Mar 16, 2007 | 07:25 PM
96TurboWS6's Avatar
Bret
how bout for trickflows with the stock trickflow valves? I know they are different lengths..and I want do the beehive setup but im not sure what to go with. I have bare lt1 trickflow heads with valves/seals
Old Mar 16, 2007 | 09:12 PM
seawolf06's Avatar
Call trickflow and ask. It would depend on the valve guides I believe among some other things.
Old Mar 17, 2007 | 02:57 AM
96TurboWS6's Avatar
they dont know anything. lol
Old Mar 17, 2007 | 10:50 AM
Use the 4705-16 for anything, it's the only spring locator out there for the springs.
Bret
Old Mar 17, 2007 | 01:13 PM
96TurboWS6's Avatar
so those would work on my heads? Im gonna be running 10-12psi through a 70mm turbo...
Old Jun 7, 2011 | 10:00 PM
95zsean's Avatar
Re: Retainers and Locks for Beehive Springs
Wish I'd of found this post before I bought the super locks.... Now my SA CC promag self-aligning tabs hit the locks before the roller's do.......
Old Jun 8, 2011 | 07:22 AM
lt1-xjs's Avatar
If you haven't already, now is the time to up grade to 7/16 studs, guide plates, chromoly pushrods and NSA rockers.
When I switched to beehives I ran across and article were the tabs hit with the S/A Promags. I ran the 787-16 retainer and the stock lock to solve the problem. This also sets the spring around 1.740" reducing the springs lift capability
Old Jun 8, 2011 | 10:31 AM
wrd1972's Avatar
I have a set of Comp beehive retainers for sale. $25 shipped.
I sent you a PM.
