Resurfacing an LT1 flywheel ? Good or not so good ?
I am getting ready to convert my 96 Impala SS from an A4 to a M6.
I have the entire setup from a '96 Firebird, it looks pretty good except it has 90k milies on everything.
The only item I 'm not sure about is the flywheel. It looks good, no overheating, no gouges etc. Looks well treated. BUT... I want to resurface it, and 'hear' that resurfacing an LT1 flywheel isn't a good idea.
I don't mind purchasing a new flywheel. No big deal at this point.
But is it really a bad idea to resurface the flywheel just a LITTLE ? Like maybe only .005 or so ?
Thanks in advance !
Gerry-
But is it really a bad idea to resurface the flywheel just a LITTLE ? Like maybe only .005 or so ?Thanks in advance !
Gerry-
sounds like I thought.... thanks for the confirmations.
There are several aftermarket clutch/PP vendors that require the resurfacing to honor their warranty, so I figured something must be up....
Urban Legend ??
Urban Legend ??
hsyr,
Thanks! This is what I've been thinking all along. Now to find a shop that knows how to do it.
I would think the surface needs to be of a certain texture or pattern or something ?? Just running it out on a lathe would make it look like a rotor when its done. Dunno if thats good or bad.
Sheesh, a new one from GM is like $181 from Dal Slabaugh. Almost tempted to just to it that way.... its a mere fraction of what this conversion is costing, and probably makes sense.
Decisions... decisions....
Thanks for all the feedback guys!
Gerry-
Gerry-
Just take the flywheel to any machine shop. They have the right machines to cut your flywheel. There is no special pattern either. I never had to pay $ to get mine cut because I knew the guy but he told me they usually charge $10 or $15 I can't remember
If you are just going to buy a new one I'll give you $30 for your stocker
Greg,
Thanks for the spec on yours, now I know what might be the worst to expect. I think that this wheel can be cleaned up super easy, probably .005 or a little more. I'm going to be using a new GM LT4 pressure plate, and a new GM LT1 clutch disc. My Impala is only making 300 RWHP and 342 RWT, and I want it to be a smooth driver. I'm also putting in 4:56's at the same time, but mainly to even out the shifts, and ease up on the 1st gear takeoffs.... still should get about 2000 rpm at 70 mph with my 27 inch tall tires in 6th, which is more than enough.
The only hold back now is that I can't find any US made 4:56's with an ABS ready pinion. Any suggestions there ? Maybe that needs to be a separate topic.
Thanks for the huge amount of feedback guys, its really appreciated. Dispelling myths is always a good thing.
Gerry-
Gerry-
Gerry, I had heard lot's of people say you couldnt resurface them and some saying you could when I was getting mine done two years ago. I was a little suprised that they had to take off so much on mine, I was worried there would be a problem but it's been fine ever since. I bet that T56 swap along with the 4:56's will really get your Imp moving
Good luck with it.
Gregg
Good luck with it.Gregg
Greg,
Always good to hear that someone has been across the same bridge. I have 'heard' both tales too, and don't really believe it. I can believe that if you take off too much yes, you will change the characteristics of the mass, the amount of adjustment you have etc. I'm already going with the McLeod LS1 adjustable master cylinder, and will use Aeroquip fittings between the two. The Impala needs a little longer hydraulic run than an F-body, so making a new hose makes sense. Also, most everyone with this Impala conversion that has experienced problems with the stock master cylinder, those problems go away with the McLeod master.
About 90 plus Impala's have been changed over at the moment, at least with the kit from Big Fast Car . The gent making this kit the last 2 years has gotten it quite complete. Add the tranny/bellhousing and clutch, his kit, and your're off!
They drive SWEET with the T56 and 4:56's. Oh yea! The kit even includes a professional makeover of the Impala center console, and it looks like like GM made it . Check out the pictures on that website. Also on my 13SecSS site
Gerry-
Gerry-
Reman'd ? I haven't looked around for one, but I think the local AC/Delco warehouse should be able to do this for me.
Now thats a good idea. That way AC/Delco would stand behind it. One of our local Impala club members is their outside sales guy, and we have a club account with them. They treat us very good.
Sure am glad I posted this. Getting all sorts of good ideas.
Thanks!
Thanks!
