Resistors for OBDII fan mod question...
Old Jul 9, 2003 | 04:58 PM
LWillmann's Avatar
I have searched around for information about the OBDII fan switch installation.
I have seen where two different resistor ratings have been used... I am confused and would appreciate some clarification.
The diagram that shoebox references HERE: http://web.camaross.com/forums/showt...hlight=fan+mod
shows 47-owm 1-watt resistors used.
A write up that I found elsewhere showed 470-ohm 1/2-watt resistors.
Radio Shack did not have 47-ohm 1-watt resistors, so I did not know what to do.
Can someone please clarify this for me?
Also, why type of Diode (what rating) should I use based on that diagram as well?
Old Jul 9, 2003 | 06:30 PM
ZYALATER's Avatar
I just did the mod and everything is working fine for me, now.
The 470 ohm 1/2 watt resistors are for between the leds and
your 12+ supply. The 47 ohm resistors go between the
switch and wiring harness in the engine bay.
I used 47 ohm 1/2 watt resistors, because radio shack didn't
have 1 watt. Works fine, so far.
Hope this helps.
Old Jul 9, 2003 | 07:03 PM
Re: Resistors for OBDII fan mod question...
Per the diagram I referenced, the rating on the diodes is 3amp. The diodes are only needed if the LEDs don't go off when the key is off.
Jeff'SS
Jun 1, 2015 06:21 AM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
79RS
Mar 24, 2015 09:30 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
aj2494
Mar 12, 2015 10:17 PM
