Requesting Dyno Feedback -- Cutout Results
Old Mar 11, 2006 | 03:24 PM
Stoopalini's Avatar
I documented this in my '1.7RR install' thread, but wanted to start one just to get feedback on these dyno results.
Only engine mods I have (besides the ones in my sig) are TB bypass, K&N filter, and a hacked factory airbox to let more air in.
How do these numbers look? Are these typical for an LT-1, or did the 1.7s really help out? Keep in mind, I don't have headers and am running a stock tune. Looks like with headers and a good tune, to lean it out, I should be over the 300hp mark.
I ran 3 times, and opened the cutout on the 2nd run.
Environmental conditions were: 91'F | 29.0-0.49inHg. | CF=1.04
Cutout Closed:
Cutout Open:
I was surprised to see 6hp and 2ft-lbs gain with the cutout open. I wonder if this would hold true after I have headers?
Thoughts??
Thomas.
Old Mar 11, 2006 | 04:03 PM
Prorac1's Avatar
Re: Requesting Dyno Feedback -- Cutout Results
FWIW, i have bbk shorties into a y pipe with the cutout where the converter used to be with a flowmaster american thunder cat back. I have no dyno numbers but i run within .05 with it open or closed, so 6 hp sounds about right. Hope this contributes, Prorac1
Old Mar 11, 2006 | 07:47 PM
2000GTP's Avatar
Those numbers seem right on... a pair of headers and a mail-order tune and you should hit 300 at the wheels.
Old Mar 12, 2006 | 08:14 AM
magnumv8's Avatar
I picked up 14rwhp with the cutout open on my 383. It was running through a flowmaster when closed.
Old Mar 13, 2006 | 10:10 AM
Stoopalini's Avatar
Thanks guys. I agree, headers and a tune are definitely next on my list.
I was hoping to be closer to the 300hp mark, but I guess the manifolds are really restricting the efficiency of the motor.
Should I wait until after the headers to get a tune, or would the tune be the same regardless if I had headers or not?
Thomas.
Old Mar 13, 2006 | 10:57 AM
atljar's Avatar
Are you doing mail order tune? Just tell them you already have headers and then you only have to send the ECM out once. It will run fine on a header tune.
Parts Wanted
May 1, 2016 10:25 AM
fift5
11
Oct 1, 2015 10:31 AM
HAWG
Sep 25, 2015 11:41 AM
tdigger9899
Sep 7, 2015 10:56 AM
