Replacing water pump. Should I do opti since im in there
Old Jan 18, 2008 | 08:49 PM
Camaro1996's Avatar
Well the water pump looked like it was leaking, so me and my buddy decided to replace it. We got it all torn down, and once we got it out, it was evident that the water pump was far gone. The bearings in the back were all shot, and it looked like there was some evidence of leakage onto the opti.
The car has been running fine, it doesnt really seem like the opti is going bad or anything. My question is, since everything is torn down, would it be wise to just replace the opti anyway?
PS Or maybe just do cap and rotor?????
Old Jan 18, 2008 | 09:13 PM
ssbowtie1's Avatar
Personally I'd do the opti.
Old Jan 18, 2008 | 09:23 PM
Pontiac_97's Avatar
if it aint broke dont fix it
Old Jan 18, 2008 | 10:41 PM
GLICKGLOCKMEX's Avatar
im with pontiac 97 just make sure you dont spill any fluid on the opti.besides have you priced one yet?ouch!but if you need plugs and wires do them now.and i would go with a ewp not a big price dif. from stock.
good luck
Old Jan 18, 2008 | 10:51 PM
Romero155's Avatar
How many miles are on the car? If you have alot I would just get it over with now so you dont have to worry about it down the road. It would suck to finish this job only to find out your opti is crapping out a few months down the road.
Old Jan 19, 2008 | 12:18 AM
itSSlowZ28's Avatar
having done both, i wouldn't do the opti unless you need to. i recently did the wp on my car and was done is a couple hours taking my time. getting the opti out, a new one on, and putting EVERYTHING back together is a lot more time consuming and potentially more expensive
Old Jan 19, 2008 | 01:01 AM
nes's Avatar
nes
id say do it, if u get it wet u might haveto replace it anyways...
Old Jan 19, 2008 | 08:06 AM
doug1105's Avatar
I agree with Pontiac_97.
If it's not missing or running rough, and you're not getting opti-related codes when you scan it, I would leave the opti alone.
Maybe take a look at the cap and rotor.
If the cap and rotor looks like it needs to be replaced, then replace that.
I wouldn't jump the gun on replacing the optical sensor (back half) of the opti.
Take a look at the timing cover seals and make sure there's no leaks there.
Old Jan 19, 2008 | 08:41 AM
speed_demon24's Avatar
I'de pull the cap off and take a look at it, then decide what to do from there.
Old Jan 19, 2008 | 09:08 AM
KeithO's Avatar
I plan on doing the same, in opposite. I will be changing my Opti soon and will do the water pump at the same time. My time is pretty important to me.
Assuming that it looks OK, I plan to keep the existing water pump as a spare.
Old Jan 19, 2008 | 02:58 PM
pizzi-man's Avatar
That is the smartest route to take. I think way too many people replace the opti when all you need is a cap and rotor.
Oncomingstorm22
Jan 22, 2015 07:15 PM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Cam28_boy
Aug 6, 2002 08:40 AM
