Biggest cam for stock LT1
Old Jan 18, 2008 | 09:30 PM
D.M.F. Solutions's Avatar
i know this gets asked alot.. but whats the most aggressive cam a stock LT1 can handle to drop that idle down,
Thanks,
D.M.F. Solutions
Old Jan 18, 2008 | 09:43 PM
Sinister95Z's Avatar
One of the reasons I made the decision to go with the Comp 503 is because I researched enough to find out that anything more without heads is pretty much a waste. I know some may argue, but that is how I took it and is just my opinion.
I personally wouldn't go any higher than about the 503's 224* 230* range for a stock head / stock bottem end.
Old Jan 18, 2008 | 09:49 PM
now is it valve train that suffers when you get a bigger cam or is it the ports?
Old Jan 19, 2008 | 12:52 PM
97SS0594's Avatar
gm847 i believe is the biggest.
Old Jan 19, 2008 | 03:53 PM
Zigroid's Avatar
I'm sticking a 242/250 112lsa in mine. stock heads, stock rebuilt bottom end except ARP rod bolts. yank pt4000 stall, gonna stick 4.10s or 4.11s in it. 125-150 lbs weight reduction. hoping to go well into the 11s.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
