Replacing Valvesprings
Old Feb 26, 2007 | 08:19 PM
BoozrCruzr's Avatar
Few questions from a newB:
I am in the process of installing an LT4 hotcam kit in my car. I'm to the part of changing the valvesprings. I've decided to do this with the heads on (because I like cruel and unusual torture). Anyways, I got the first spring off and found that the valvespring has a little stamped steel cup on the bottom of the spring between the spring and the head. The kit comes with new ones, but do I have to replace them? They don't just slide off...looks like the valvestem seal?? is in the way.
While on the topic, should I change the valvestem seals? If so, how do I do that.
Finally, what is the best valvespring compressor to use. I bought one at Napa for like $30 and I can tell I'm going to throw it threw a window before I finish this job.
Thanks!
Chad-
Old Feb 26, 2007 | 08:33 PM
zx1216's Avatar
did you get the one with the hand crank on it? if so it will save your hand if you can get to a welder and weld a nut on the top to use a rachet or wrench...
Old Feb 26, 2007 | 08:54 PM
BoozrCruzr's Avatar
No, I bought one with a handle that flips closed and compresses the spring. Handle can be changed out with a bolt which works better, but it still sucks.
Chad-
Old Feb 26, 2007 | 09:02 PM
OBE1 95Z28's Avatar
I would change the valve stems seals and replace the seat locators. The old seals will pull off with vice grips. The new ones get tapped down until they are fully seated. I use a deep socket to perform this; there is a tool you can buy. You want to make sure you don't tear the seal when sliding down over the top of the valve stem. They have a small cap that fits over the end of the valve stem to help install.
Old Feb 26, 2007 | 10:40 PM
Thanks!
Chad-
Looking through this might answer some of your questions.
HectorM52
Jul 30, 2017 11:46 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Hurin
Dec 13, 2014 07:38 PM
RichJ
Sep 26, 2002 09:43 AM
SNEAKY NEIL
Aug 16, 2002 10:59 AM
