Replacing Valve seals.
Old Jun 13, 2003 | 08:58 AM
GetaZforgetGT's Avatar
I thought that you can remove them by hand but comp cams sells a removal tool.
Is there anything I should know before I attempt this.
Trick, Tips, etc.
Old Jun 13, 2003 | 09:00 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
are you reffering to a valve spring compressor?
KCFormula's Avatar
To get them initially loose you might want to use the removal tool so that you dont damage anything on your heads. I suppose if you were very careful you might get away with using a screwdriver.
Old Jun 13, 2003 | 09:11 AM
treyZ28's Avatar
we reused the valve seals when we used a skrew driver-
its not that hard, no special tools needed
Old Jun 13, 2003 | 09:53 AM
Don 97 SS's Avatar
Reuse them They are clearly a wear item. For $20 why not just replace them with a fresh set?
Old Jun 13, 2003 | 10:00 AM
treyZ28's Avatar
it wasn't my car, i was helping a board member in the area.
he thought the Lt4 HC kit came with valve seals...
it was either reuse them or none at all
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jazsun
Dec 29, 2014 12:14 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
