Replacing Starter
Old Sep 19, 2003 | 02:16 PM
Don't Look Back's Avatar
Replacing Starter
Hey guys, the starter on my 95 Z took a crap today, so I am replacing it. I've already gotten under the car and try tapping on it with a hammer to get the car to start in order to get it to my cousin's shop with no luck. Therefore, I have no access to a lift. My question is, how hard is it to replace the starter on our cars? Is there anything that complicates it such as placement of other parts, etc.? And finally, can I replace it by jacking it up in my driveway? I've done starters before, just never on an F-Body, so I don't know what to expect.
Thanks, Keith
Old Sep 19, 2003 | 02:18 PM
madwolf's Avatar
I've replaced mine... well, actually had to drill out a broken starter bolt too... long story. But from what I've seen, you will need to drop your y-pipe.... Then it's easy and yes, you can do it in the driveway.
Old Sep 19, 2003 | 02:30 PM
PPcc's Avatar
I hope it is this easy, my starter also went south on me. There goes my weekend..
Old Sep 19, 2003 | 02:33 PM
madwolf's Avatar
The hardest part will be dropping the y-pipe. If your bolts are really rusty and you brake them, you might need another weekend.
I'd spray them with some PB Blaster prior to removal. Some heat might help too.
Old Sep 19, 2003 | 02:36 PM
JoeliusZ28's Avatar
I just changed the starter on my '95 Z and it slipped right by the Y-Pipe....
Old Sep 19, 2003 | 02:38 PM
madwolf's Avatar
Hmm... I didn't have to change it on my '95 M6, but on my '93 A4, I couldn't take it out without dropping the y-pipe...
Old Sep 19, 2003 | 02:40 PM
JoeliusZ28's Avatar
...I can see where the a4 would make a difference
I guess just try going around it b4 you rip it out
Old Sep 19, 2003 | 03:06 PM
Alright, thanks for the replies guys. I'll try to do it without dropping the pipe. Worse comes to worse I'll drop the pipe.
Old Sep 19, 2003 | 03:11 PM
TedH's Avatar
Be grateful you don't have a tranny cooler. I had to drop mine to replace the starter. It was quite messy.
Old Sep 19, 2003 | 07:15 PM
Bud M's Avatar
If you need to drop the y pipe (I would) hit the bolts with PB Blaster first. Otherwise it is a straightforward job, no big deal.
Old Sep 20, 2003 | 02:48 AM
Alright, so assuming all of the bolts come undone, is it relatively easy to drop the Y-pipe?
Old Sep 20, 2003 | 02:55 AM
madwolf's Avatar
Yea... just remove.
Really, you probably won't even need to take it out completely. Once you take out the bolts, you can loosen the cat bolts and that should give you enough room.
Old Sep 20, 2003 | 06:19 AM
Van5150's Avatar
I have the A4 and replaced my starter withouth removing the Y-pipe or tranny cooler lines. You do want to move/bend the lines out of the way. And the position the starter will eventually slide out is after you unbolt it, turn the starter straight up, with the starter gear at the top, and pull it through the bottom. You have to roatate it a bit,and once you do it once, you will never forget.
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Feb 5, 2015 11:04 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
