Replacing Spark plug wires
Old Mar 29, 2005 | 09:53 PM
havoc06432's Avatar
I'm just about to replace my spark plug wires. My car is a 1994 z-28 with auto trans. What plugs should I use? I concerened about performance gains, cost, and heat resistance. I'm a bit confused about which wires need heat sleeves and which ones don't. What have you guys used in the past? Stock, Accel, MSD, Taylor? What have been reliable?
Old Mar 29, 2005 | 10:09 PM
havoc06432's Avatar
Re: Replacing Spark plug wires
oops I meant to say which wires should I use. I replaced my plugs two months ago with splitfires. What wires fit wich factory wire loom?
Old Mar 29, 2005 | 10:13 PM
Myxtreme1's Avatar
Before my motor became an experiment I was just using the cheap ones from advance with absolutly not problems in the stock locations. They are also a little longer if you want to route other ways. Then I melted one after the header install then pulled the motor. Now I am going to use Thunder Racing OTV kit. A very good investment IMO.
Old Mar 29, 2005 | 11:23 PM
blitzer454's Avatar
If you want to stay in the stock looms then go with a 8mm wire, anything bigger and you're going to have a tough time squeezing them into the looms. I used the Taylor Spiro Pro with no fit problems and the lengths are pretty close to stock.
Old Mar 30, 2005 | 10:09 AM
havoc06432's Avatar
Thanks I was looking at the Taylor spiro pros. I just wasn't sure if I had to surround them with heat sleeves.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
