Replacing the reverse gear syncromesh
Old Jul 31, 2003 | 09:28 PM
Rodrigues's Avatar
Is this something I would want to try myself? I just removed my T56 for a new clutch and my reverse gear pops out and I am pretty sure its the reverse gear. I also heard that you can flip it over, is this true?
Old Aug 1, 2003 | 02:30 AM
limige's Avatar
hey i just did mine last year, it was probably my post you read.
yes, it works like a charm, the speedo gear is the only pain, but i can help if you need. putting it back together takes alot of wiggling too!
later,
mike
ps: a real good set of snap ring pliers, those suckers are heavy duty and only about 1 1/4 big.
Old Aug 1, 2003 | 11:51 PM
Rodrigues's Avatar
I'm scared im going to ruin something inside of it. Ill open her up tommorow and see... Did you have to replace any parts?
later,
mike
Old Aug 2, 2003 | 04:37 AM
limige's Avatar
no, just pulled everything apart and flipped the syncro around, oh and the little plastic thingys on the shifting forks, mine were pretty worn out, i flipped those around, you might want to see if univeral trans on dequindre has some. i'd replace those if you could if not no biggy.
pay attention to everything you take off, note the direction it faces and order things go in, shoebox has a manual you can download on his site for the T56, helps a ton!
make sure you have plenty of clean room to disassemble, lay the parts out in the order you take them off, mostly just common sense.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
mattszm6
Dec 14, 2014 07:09 AM
kizz
Aug 28, 2002 09:39 PM
