Replacing Rear Main Seal, How? And What Do I Need?
Old May 8, 2005 | 01:30 PM
Xride's Avatar
I need to replace my rear main seal, 9 year old car and 9k miles = dried up leaky seals.
It doesnt leak bad, but drips a couple drops a night.
I know I need the seal... but do I need any sealants?
How do I change it? or is it pretty simple?
Will I need any tools outside the basic? tq wrench maybe?
How hard would replacing the throwout bearing be at the same time? it rattles ever so slightly when cold, might as well get it while I am in there.
Old May 8, 2005 | 05:33 PM
Xride's Avatar
Re: Replacing Rear Main Seal, How? And What Do I Need?
bump?
Old May 8, 2005 | 06:33 PM
hsyr's Avatar
Its about as hard as changing a clutch, since you have to remove it to get to the seal. Do a search on here for a guide on changing clutches. Once you get the flywheel removed then you can just use a flat head screwdriver to pry the old seal out. Hope this helps
Old May 8, 2005 | 08:18 PM
ACE1252's Avatar
Here ya go....
http://zachz28.8m.com/z28/tutorials/clutch/clutch.htm
Old May 8, 2005 | 08:30 PM
Xride's Avatar
Originally Posted by ACE1252
Looks like one hell of a job.
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
Jazsun
Dec 29, 2014 12:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
