replacing the power steering pump
Old Oct 10, 2003 | 03:46 PM
  #16
illegalactivist's Avatar
i don't really want to have to go out and buy a ton of special tools that i'm not going to need later on when i'm kind of tight on cash... if it's possible to do it with regular tools, i'd rather do it that way...
and, btw, if the new pump has a pulley on it already, am i still going to need the pulley puller?
- jay
Old Oct 10, 2003 | 04:17 PM
  #17
naztyz28's Avatar
if it has the pullie on it then no you wont need it and line wrenches are not expensive and well worth it. why make more work if you dont have too.
Old Oct 10, 2003 | 09:11 PM
  #18
Bad AZz Z28's Avatar
Originally posted by kmook
How To
Pics
sweet, i was just outside messing around with some things after it started to get dark out, and i couldnt quite find one last bolt until i happened to see it in one of those pics...got alot done after that was out of my way, so thanks
Old Oct 10, 2003 | 09:46 PM
  #19
TA Dreaming's Avatar
dont mangle the line fittings on the pump you will be in a world of hurt and way over budget. try it with a regular wrench if itll come loose great. if it starts to slip at all stop and go get some line wrenchs. line wrenchs are actually very useful and i highly recomend them. just get a simple set the goes from 3/8 to 3/4 or 7/8. youll use them over and over just like a normal wrench. they are not a waste of money or a special tool thats rarely used. just letting you know. your cars not very old so you want have the problems i encounter at work while working on some of the old vettes. but all the same its money well spent. Trey
Old Oct 11, 2003 | 05:19 AM
  #20
how much do they run? i might have to go by the parts store and pick up a small set...
- jay
Old Oct 18, 2003 | 05:07 PM
  #21
dont know we get ours from snap on and you dont wont to know how much they cost. it shouldnt be too bad. they are worth the money spent on them, just make sure you get good ones with a lifetime warranty. trey
HectorM52
Jul 30, 2017 11:46 AM
ANDYZ28
Dec 29, 2014 09:13 PM
ro2207
Dec 4, 2014 06:18 PM
