Replacing PCV valve (Rookie question)
Old Jul 17, 2012 | 07:54 PM
Jon8903's Avatar
1995 Camaro Z28
I've noticed an oil leak coming from the front of my engine, it is a steady drip once the engine is hot and decreases as the engine is off and the pressure drops. I've had one mechanic say it's the timing valve gasket and another suggest it could just be a bad PCV valve. I'd like to try to replace the valve myself ($350 in A/C overhaul, EGR, plugs and wires repairs already this week) as it's a $2 part and couldn't hurt to try.
If y'all wouldn't mind, could you give me a description of where the valve is located and how I'd go about changing it out? Pictures would be appreciated
Old Jul 17, 2012 | 11:37 PM
Re: Replacing PCV valve (Rookie question)
Driver's side of the intake manifold.
Courtesy of Shoebox
http://shbox.com/1/pcv_pipe.jpg
http://shbox.com/1/pcv.jpg
The valve just pulls out of the thick rubber grommet on the manifold.
Shoebox has the best source of LT1 information on the internet. IF you haven't been there yet, take a look, and bookmark it. You're going to need it:
4th Gen LT1 F-Body Tech Aids
Old Jul 18, 2012 | 10:38 AM
mrmint69's Avatar
It should fit snug and stay tight. Make sure it isn't loose and clean the area good where it goes.
Old Jul 19, 2012 | 12:50 PM
Jon8903's Avatar
Thanks for your help. I got the new valve last night and removed the old valve from the engine and disconnected the 2 inch straight rubber hose from the PCV line. In the process of removing the old valve I noticed that this little bit of hose was worn and cracked and think I made it worse by pulling the old valve out of it. I reinstalled the new valve into the hose and replaced the valve into the engine and the the hose into the line but I'd like to replace that little bit of hose to make sure I have a good seal.
Long story short, what kind of hose should I look for to replace that little bit? Just a standard fuel line hose or something more heavy duty? Is it a 3/8" (.375 diameter)? Would it be a good idea to replace the grommet as well? I've seen several listed on Advance Auto's site put I'm not sure which matches "10240678 - PCV Grommet" from shoebox's site.
Old Jul 19, 2012 | 01:16 PM
It has to be "vacuum" hose, intended to resist collapse under vacuum. That's why it's so thick. Fuel line is designed for pressure. Most auto parts stores will have rolls of various size vacuum hose. They just cut off what you need.
Shoebox lists the GM factory part number. Auto parts store should have an equivalent.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
