replacing passenger side plug wires
This is my first time doing a tuneup, and surprisingly, the plugs were a breeze - didnt have to remove anything. (must be my girlishly small hands). Anyhow, how do you remove and re-route the passenger side plug wires? The pulley and sway bar in the way and I cant seem to get them off the opti.
Any tips?
Regards,
Michael.
Any tips?
Regards,
Michael.
i just got finished installing my opti and waterpump not too long ago..in order to do so, i had to remove the balancer hub(main pulley drive) and the serpentine belt. if im not mistaken...from below, youshould be able touse the tensioner...and easily drop the serpentine belt then pull off the three bolts holding on the pully...then youve got perfect access to the opti/plug wires
i may be wrong, the waterpump may be in the way..id have to look again.but its really not that hard....the hardest part is getting tothe rear two (6 and 8) plugs on the RH side (passenger)...im about to do plugs/wires myself...good luck!
Jul 4, 2005 05:00 PM
