Replacing Oil Pan Gasket on Canton Road Race Pan
Last winter on my 95' Trans Am I put on my Canton Road Race Pan and reused my Fel-Pro blue oil pan gasket that is a 1 peice. I used rtv on the 4 corners and it leaks above the starter, but mostly under the rear main seal. Is there any way to change it with the motor in the car? I have the trans out, flywheel off and heads off. Or anyone have some suggestions?
Re: Replacing Oil Pan Gasket on Canton Road Race Pan
You just remove the engine mount bolts and jack-up the front of the engine far enough to get the pan off. Watch the wires, tubes, lines, etc. so you don't stretch and break something.
It's a bitch as I have the same pan and have done it twice. Do as stated above and you should be able to get it out, but it's gonna take some time and a few curse words. I ended up having to rotate the motor over a few times to get the rod bolts to clear when pulling it out. FYI - Pulling the tranny makes it much easier as you don't need as much clearance when pulling it back.
With the trans/bellhousing out it should be easy, just make sure you are able to rotate the motor while it's jacked up because you will have to get the front counterweight up in the block to pull it easier.
Block of wood and bottle jack under the crank pulley. Some guys will say don't do it but some will say it's fine. I've done it several times and zero issues.
Awesome, might do this project tomorrow then. The motor mount bolt you speak of is the long one through the middle? Or where it bolts to the motor? Or kmember? Sorry for all the questions.
I used a jack and wood under the crank which is why I said make sure you are able to rotate the motor. You can't rotate the motor if you are lifting it at the hub. The motor mount through bolts are the ones to remove. I would remove all the pan bolts and lower the k-member a little to see if you need to rotate the crank to get the front counterwieght out of the way. Then jack it up at the crank hub to slide it out.
Forgot to mention that when I do it the car is on jackstands already with the front tires off the ground.
