Replacing Heater Hoses
Old Aug 7, 2007 | 05:24 PM
Ultra_Dog's Avatar
I just discovered a pin-hole in my heater hose, spraying on my headers. The hose is a seal/crimp that is $160 as a whole unit (from radiator to heater core). Only the rubber hose, near the firewall, is actually leaking. Does the whole enchilada need to be replaced? Sure looks like a total PITA. I don't doubt it needs replacing (10 years/172,000 miles).
Suggestions?
Old Aug 7, 2007 | 06:06 PM
You can buy the individual rubber hoses and remove the swaged collars to put them on. Just use a regular hose clamp to put the new hose on.
Old Aug 7, 2007 | 08:47 PM
mourningyou's Avatar
I bought the whole assembly, and it was STILL a pain to get in there. I wish I would have saved my money and just replaced the hoses myself. Perhaps with the headers it would be easier, but with manifolds it was a pain in the neck. There are either one or two bolts that attach the middle "hold down plate" to the fenderwell, and they were hard to get a wrench onto.
Also, I must have crossed the hoses onto the wrong ports on the water pumpbecause my heater doesn't work. Good thing I live in flori-duh.
Old Apr 28, 2008 | 02:17 PM
Compstall's Avatar
When you changed the assembly, how did you get it out/in there? I sure as hell can't figure it out and threw in the towel on it last night. I could cut the old one in pieces and get it out, but that wouldn't work too well for the new assembly.
Old Apr 29, 2008 | 09:25 PM
Chewbacca's Avatar
I just did mine two weeks ago (the day before I had to leave for a weekend of racing).
It was a PIA as you have already found out. I wrestled them in and and out the top. There's really no other way to do it that I could see. You just have to find what works. Took me almost three hours.
I do all my own work on the car (clutches, diffs, alignments, etc, etc). I can honestly say that out of all of it, replacing the heater hoses REALLY sucked so don't get discouraged.
Old Apr 29, 2008 | 10:11 PM
Compstall's Avatar
The only way I saw it could come out was if I took the main accessory bracket off, which snowballed into removing the power steering pump & lines, tensioner pulley, and a/c compressor mount bolts. Even after studying it then I was not positive that I could have gotten those hoses out so that's why I threw in the towel on it.
This is honestly the first time I've really been skunked on this car...
Old Apr 30, 2008 | 01:14 PM
Warren_Seale's Avatar
Even the shop manual recommends replacing only the rubber parts of the hose assembly. There was no mention of removing the pipes for a LT1 car.
If you remove the starter, can you remove/install the assembly from underneath?
Warren
Old Apr 30, 2008 | 01:23 PM
Compstall's Avatar
Warren
Now you got me thinking if that's possible and why I didn't think of it when I had the starter and everything out of the car the other night...
Old Apr 30, 2008 | 01:38 PM
ss.slp.ls1's Avatar
I had two different hoses go out on me. I just cut each sections with the hole and clamped on a new one.
Old Apr 30, 2008 | 01:47 PM
maverickmk's Avatar
I had cut one of the hoses when I replaced the AC hoses and used one of those coolant flush valve things to bridge the gap and put clamps on it. It worked great until I pulled the motor and replaced the whole assembly.
dalynchmob
Feb 19, 2015 07:20 PM
Jlo
Feb 3, 2015 09:41 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
