Replacing head gasket tips?
Old Sep 22, 2005 | 09:47 AM
GOTPLZ2's Avatar
I kept fouling my number 6 sparkplug and noticed I had a header leak on that side. I tightened it up but still got black exhuast dust on the heads above the 4 and 6 primaries. I am hoping that replacing the gasket while stop my exhaust leak and keep the sparkplug from fouling out. I unbolted the passenger side header and scraped off the old gasket and went to install it again with the new gasket but it is a PITA. Does anyone have any tips on reinstalling The passenger side header?
Old Sep 22, 2005 | 10:17 AM
Bawls's Avatar
Re: Replacing head gasket tips?
For longtubes I typically pull the motor mount bolt out on the passanger side, and jack up the passanger side of the motor a few inches. Slides right in.
I dont think you'd have pulled the header though just to replace the gasket.
Old Sep 22, 2005 | 10:52 AM
GOTPLZ2's Avatar
No the header is still installed and I can push it up to the heads but can't seem to line it up good enough to get a bolt started.
Old Sep 22, 2005 | 11:32 AM
96SSM6's Avatar
Get a buddy to come over and support it from the bottom.
Old Sep 22, 2005 | 12:37 PM
GOTPLZ2's Avatar
Usually that's harder than doing it myself. I'd could have my gf help me if it wasn't for that getting dirty thing.
Old Sep 22, 2005 | 01:27 PM
96SSM6's Avatar
I guess that why I keep mine around, shes down to get dirty. I actually did it mysel, though. I stuck a piece of allen wrench (cut aff the L w/bolt cutters) in the head and hung the front of header, then support the rear and start threading. Worked for me. Hope it helps
Old Sep 22, 2005 | 01:35 PM
GOTPLZ2's Avatar
Thanks. I think I'm going to stop by the hardware store and get a long bolt and cut the head off of it. I'm hoping that if I screw it in and slide the heads onto the stud I can line it up good enough to get some of the other bolts started.
Old Sep 22, 2005 | 01:47 PM
96SSM6's Avatar
I did that the first time. You can just buy threaded studs. Be sure to put them where you can get the vise grips in there good. Mine didnt come out to easy.
Old Sep 22, 2005 | 02:09 PM
GOTPLZ2's Avatar
What size studs did you use and which holes did you put them in?
Old Sep 22, 2005 | 02:13 PM
96SSM6's Avatar
I think the 3rd and 5th from the frnt. Dont remember the size/pitch. Think its 3/8-16. Just take a header boltw/. Measure it there.
Old Sep 22, 2005 | 02:36 PM
GOTPLZ2's Avatar
Yeah I was going to take a header bolt with me to get the thread. I should of asked how long of a stud should I get. I thought about getting one about an inch long.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
