replacing head gasket
ok guys.. im going to replace both of my head gaskets and ive been told two differnt things
1. that just take off the covers and and the cylinder covers... pull of the old head gasket and put the new one on...
others have said
2. go by the chilton manual...
is it really just bolt off and on or do i need to do all the crap the manual says
By covers I am assuming you mean valve covers. You are leaving out the intake manifold, Exhaust manifolds and crossover tube. That is off the top of my head. You also need to have the heads checked if you are replacing a blown gasket and you are supposed to replace head bolts. I highly recommend a Chiltons manual especially if you have never done this before.
