Replacing cooling line hoses??
Old Oct 2, 2003 | 03:15 PM
kgkern01's Avatar
I need to replace the hose from the coolant bleeder valve to the water pump. First, I have to order this because no one carries it, not even a dealer. Second, when I do replace it, do I just cut the clamp off on the valve end of the hose, then use a normal hose clamp when replacing? How exactly is this done CORRECTLY?
Old Oct 2, 2003 | 04:04 PM
RamAir95TA's Avatar
Do you mean the hose from the water neck (with the bleeder screw) to the base of the radiator?
Old Oct 2, 2003 | 05:17 PM
From the bleeder to the pump would just be a little elbow hose. Regardless of what hose it is, just cut off the swaged part that clamps the hose on the bleeder pipe. You can then slide your new hose on and use a hose clamp to secure it.
Old Oct 2, 2003 | 08:50 PM
kgkern01's Avatar
Thats what I thought, just wanted to make sure before I go cutting anything.
Old Oct 3, 2003 | 10:51 AM
Mtrhds94Z's Avatar
Number 7 in shoebox' diagram from his site:
http://csce.uark.edu/~jgbertr/rb/heater_hoses.jpg
GM 95-7 p/n 10215999[same p/n for 93-4]so GM does sell it seperately...
Or get a 5/8" preformed elbow from an auto supply place.
Cut a slit [carefully! not too deep!] in the swaged clamp with a Dremel etc and put a screwdriver in the slit to open it and pry it off.You don't reallty need to cut it all just most way thru then it'll easily break when you put screwdriver in slit and twist it.
The bleeder pipe has a ridge to hold the new hose on with a regular clamp.
Water pump end is a regular clamp.
[edited error in p/n]
HectorM52
Jul 30, 2017 11:46 AM
MattFick
Feb 15, 2015 10:16 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
