Replacing cam bearings
Old Aug 17, 2006 | 05:52 PM
Demus's Avatar
What's the procedure for replacing cam bearings? I've never done it before, but I have access to a SBC cam bearing removal/install tool. Does the engine have to be out of the car?
Old Aug 17, 2006 | 06:50 PM
wrd1972's Avatar
Re: Replacing cam bearings
Unless you are a magician, it would be easier remove the engine from the car.
Once out the can be removed and re-installed with the specialized tool.
Old Aug 17, 2006 | 07:28 PM
396D1SS's Avatar
the crank and rods should be out for a proper install also you have to line up the holes with the cam bearings and the oil passages for cam lubrication...... with a bare block i installed mine in about 5 minutes
Old Aug 17, 2006 | 09:13 PM
Yes, the engine will need to be out of the car. It's not hard to do with the correct tool. Just make sure you orient the oiling holes correctly.
Old Aug 17, 2006 | 10:41 PM
1racerdude's Avatar
Make damn sure ya clock them right or ya will ruin them in a heart beat,along with the cam and other things.
Brandon Wittmer
Dec 20, 2014 09:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
