Replacing burned out headlight
Old Feb 28, 2003 | 06:39 PM
mike95z28
Guest
Posts: n/a
I went over to a local car parts store to replace a burned out driver's side low beam headlight. Do I have to replace the entire sealed unit? Or can the lightbulb be replaced?
Old Feb 28, 2003 | 06:44 PM
1RedHotZ28's Avatar
Re: Replacing burned out headlight
You have to replace the whole thing....that's the only way they come...
And they AREN'T Cheap
Billy
Old Feb 28, 2003 | 07:07 PM
snakeatinZ's Avatar
Ready for more bad news!!!....... The other one is not that far behind it! Give it one month it will go out as well. I am not trying to jinx ya, but that is what I gathered from my own experiences!
Old Feb 28, 2003 | 09:47 PM
RENE95Z's Avatar
http://www.sps1.com/Head%20Lamp%20Mod.htm
This should answer your question.
Old Feb 28, 2003 | 11:15 PM
mike95z28
Guest
Posts: n/a
The Sylvania replacements were like $24.95. Not too expensive imo. Guess I'll head over tomorrow to replace it.
Old Mar 1, 2003 | 12:47 AM
GPZ1100's Avatar
The mod 2 links back does work indeed. Though using jb weld is a perm solution, so next time around you will be replacing the entire assembly.
I picked up some sylvania XTRA vision bulbs.. ~$20 for the pair at autozone.
My headlamps were not burned out, but were original (from 1997). In all honesty, I barely notice any 'additional' light with the new bulbs in.
Biggest change in lighting came from getting ride of the trash stock fog lamps and putting some catz MSZ lamps (they fit the stock locations perfectly). The car is quite drivable now on country back roads.
HectorM52
Jun 23, 2016 08:42 PM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
