replacing AIR metal pipes with rubber hose
Old 08-07-2003, 08:55 AM
RichJ's Avatar
Does anyone see any long term problem with cutting out the annoying metal plumbing of the AIR pump system and running rubber hose above the motor instead? This is what I've done and I'm wondering if it's safe to leave alone since I'm running cats on my car again. The only issue I can think of is heat from the headers on the hose and potentially melting the hose if one of the check valves fail.
It is great for working on the car though since those stock metal pipes always seem to be in the way of everything when you are working under the hood.
RichJ is offline
Old 08-07-2003, 09:03 AM
LT4POWR's Avatar
I tried it and the hoses kept melting. Good Luck
LT4POWR is offline
Old 08-07-2003, 09:04 AM
Geezer powered's Avatar
Well the only long term promblems would be like you said from the heat.From the factor they used metal for some reason and that is probly it.
Geezer powered is offline
Old 08-07-2003, 09:13 AM
TheHeadFL's Avatar
LS1s use all rubber, from the factory, I believe... so take that for what its worth.
TheHeadFL is offline
Old 08-07-2003, 09:14 AM
chevroletfreak's Avatar
My 93 also has all rubber going to the check valves. They run just above the valve cover.
chevroletfreak is offline
HectorM52
07-30-2017 11:46 AM
redleader
Parts Wanted
11-13-2016 02:57 PM
redleader
01-22-2015 12:05 PM
94Z28LS1toLT1
01-15-2015 07:18 PM
95chwagon
01-13-2015 09:19 PM
Quick Reply: replacing AIR metal pipes with rubber hose
