replacing AIR metal pipes with rubber hose
Old Aug 7, 2003 | 08:55 AM
RichJ's Avatar
Does anyone see any long term problem with cutting out the annoying metal plumbing of the AIR pump system and running rubber hose above the motor instead? This is what I've done and I'm wondering if it's safe to leave alone since I'm running cats on my car again. The only issue I can think of is heat from the headers on the hose and potentially melting the hose if one of the check valves fail.
It is great for working on the car though since those stock metal pipes always seem to be in the way of everything when you are working under the hood.
Old Aug 7, 2003 | 09:03 AM
LT4POWR's Avatar
I tried it and the hoses kept melting. Good Luck
Old Aug 7, 2003 | 09:04 AM
Geezer powered's Avatar
Well the only long term promblems would be like you said from the heat.From the factor they used metal for some reason and that is probly it.
Old Aug 7, 2003 | 09:13 AM
TheHeadFL's Avatar
LS1s use all rubber, from the factory, I believe... so take that for what its worth.
Old Aug 7, 2003 | 09:14 AM
chevroletfreak's Avatar
My 93 also has all rubber going to the check valves. They run just above the valve cover.
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
95chwagon
Jan 13, 2015 09:19 PM
