Is the replacement part of the cam swap easier than the removal?
Old Mar 9, 2004 | 10:54 PM
sc93's Avatar
I would think so...
Hopefully everything bolts back up smoothly My back is starting to hurt, lol
Old Mar 9, 2004 | 11:17 PM
JJ's95B4C's Avatar
LOL...i hope so too. My cam should get here tomorrow and as soon as it does, everything is going back in. I have the car taken apart ready for the cam.
Old Mar 9, 2004 | 11:28 PM
sc93's Avatar
Originally posted by aggiez28
you could say it is becasue when your putting everythign back you know whre it goes b/c you just took it off.
(this applies if its your first time)
brook
yep, first timer here
Old Mar 9, 2004 | 11:35 PM
S.J.S.'s Avatar
I would say harder as far as installing the cam because you have to be super gentle when putting it in to make sure you don't knick the bearings. Pulling out the old one you can just support it with your hand but the new, beacause of the lube, your just using those 6" bolts to guide them in. I hated it. Just kept thinking....."there's another knick" lol
Old Mar 9, 2004 | 11:43 PM
sc93's Avatar
lol, yeah I'll be super careful with that part
although I've heard that you don't have to use cam lube, just some regular oil on the cam before you put it in Comp didn't send me any cam lube with the cam
Old Mar 10, 2004 | 12:01 AM
Compstall's Avatar
Generally speaking, most things are easier to take apart than they are to put together....
Old Mar 10, 2004 | 12:03 AM
Jason Dove's Avatar
It's not the install that's hard. It's finding the bolts you misplaced that's the pain.
Old Mar 10, 2004 | 10:29 AM
leadfoot94's Avatar
Yes, mine also came without cam lube. I was also wondering about this.
Old Mar 10, 2004 | 11:26 AM
CamaroBoy96Z28's Avatar
Oil should be fine. We used oil on my friend's cam when putting it into his 302 last weekend. Just make sure to use a lot of oil/lube.
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
chuyz28
Nov 25, 2014 11:14 PM
Elcojoe
Nov 17, 2014 10:27 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
