Need Throttle Body gasket part numbers...
Old Mar 9, 2004 | 07:01 PM
AxeGrinder30thZ's Avatar
I need the part numbers for the stock LT1 throttle body gaskets for a 97 LT1. I'm seeing people say that some are sold seperately and what not, and I just simply need all the gaskets that are required to put a stock throttle body on. Hope someone can help.
Old Mar 9, 2004 | 08:32 PM
Anyone?
Old Mar 9, 2004 | 09:00 PM
Paul94Z28's Avatar
Gasket #s
AxeGrinder-
There are three gaskets, upper and lower water jacket, and tb to manifold. I just bought the upper and lower ones as a kit. The TB to manifold appears to have to be bought separately.
The pn was 17113074 and lists for 12.98.
Good luck.
Old Mar 9, 2004 | 09:07 PM
Mtrhds94Z's Avatar
TB to Manifold Gasket GM 10105379
Old Mar 9, 2004 | 09:08 PM
BlackDog's Avatar
10105379 - This is to attach tb to manifold
17113074 - This is a gasket kit which includes the top plate and bottom plate gaskets only.
You would need both part numbers for the whole tb. If you just need the gasket to attach the tb to the manifold, then go with the 1st part number.
Scott
Old Mar 10, 2004 | 05:48 AM
Where would be the cheapest place? GMpartsdirect? I checked on their site and the total is $22.60 shipped for all gaskets. That seems high for just gaskets. Anywhere else?
Old Mar 10, 2004 | 07:31 AM
Jason or Dal.
If all you need is a gasket to install the TB to the intake, just go to your local auto parts store and get one. If the TB is on the car now and you have not taken it off, chances are the gasket can be reused as long as it does not get torn.
Old Mar 10, 2004 | 07:56 AM
Originally posted by shoebox
Jason or Dal.
I need the gasket for the TB to intake and the bottom. I have a stock TB that needs to replace a BBK 52mm TB. When you guys say top gasket, are you referring to the gasket for the top TB plate? The plate is already on there, so I don't suppose I need that one...just the TB/manifold and the bottom one.
Old Mar 10, 2004 | 09:26 AM
agent z28's Avatar
The lower gasket for the IAC housing is not sold separately. GM does offer a complete gasket set, comprised of four pieces. I don't have the part number, but I can tell you it cost me a lot more than the price you gave from GM Parts Direct. The complete TB set will include a gasket for the IAC motor, clean air cover, IAC housing and TB to intake.
Old Mar 10, 2004 | 09:43 AM
ppmz28's Avatar
Trey, I paid 12.98 at upstate chevy for the whole kit, that only included two gaskets, one was the plate and the other was a funny shaped one, I can give you that weird shaped one if you need it.
Old Mar 10, 2004 | 09:45 AM
ppmz28's Avatar
I only used the plate gasket(forgot to mention)
Old Mar 10, 2004 | 11:28 AM
agent z28's Avatar
In my haste I forgot to mention I have a spare TB to intake gasket that I can send you for the cost of postage. Its a Holley replacement intended for a 52 mm TB. E-mail me directly if you're interested.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
