replaced head gaskets, coolant leak.
Old Aug 24, 2012 | 08:43 PM
bowhunter11's Avatar
Question replaced head gaskets, coolant leak.
im ASE certified so i have knowledge on this subject but this is my first time replacing head gaskets on a corvette engine.
its my GFs car, 1995 LT1 Camaro 130,000 just replaced the head gaskets.
i had a leak coming from the banjo bolt that holds the coolant line to the drivers side of the head.
i replaced that bolt but there is still a little leak.
i think i might have missed something that goes in the back of the drivers side head.
so what all goes into the back of the drivers side of the head????
banjo bolt and what else?
picture sure would help!
Old Aug 24, 2012 | 09:00 PM
jloshotz's Avatar
Two of these on either side of each banjo GM part # 10108689
Old Aug 24, 2012 | 09:36 PM
Re: replaced head gaskets, coolant leak.
is there anything else that goes on the back of the heads?
Old Aug 24, 2012 | 11:50 PM
jloshotz's Avatar
I too have a 95z, and that is all that is on mine
Old Aug 25, 2012 | 05:53 PM
thx! picture helped alot. i kept reaching my hand back to the rear of the heads and felt what i thought holes for something to screw into.
gonna replace the seals with new one tonight
Old Aug 25, 2012 | 08:21 PM
jloshotz's Avatar
Just got my engine in today, just some small buttoning up and tune uploading in the morning Glad the pic helped!
Old Aug 25, 2012 | 10:11 PM
so i took the banjo bolts out and replaced the "gaskets" on both sides of the bolt and put thread sealer on it, but i am still losing alot of coolant from that area!
Old Aug 25, 2012 | 10:18 PM
jloshotz's Avatar
Sorry to hear...Grab an inspection mirror and see what gives
Old Aug 25, 2012 | 10:30 PM
Shoebox's photos may help as well:
http://shbox.com/1/egr1.jpg
http://shbox.com/1/steam_pipe_seal.jpg
Old Aug 29, 2012 | 09:46 PM
lt11997's Avatar
I had one of those banjo bolts leaking on a customers car a few weeks ago, tried replacthing just the gaskets but the coolant still kept on pouring out of there ( somebody had just done a head gasket on it and rounded off one of the banjo bolts head and reused the old gaskets). Since you can't get them banjo bolts from gm I just told the customer I had to make a new line and did something like thishttps://www.camaroz28.com/forums/lt1...cement-793480/ After I got all the pieces rounded up it only took about 30 min. to do with the engine in the car and will do it to mine if it ever starts leaking.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
