Replace waterpump?
Old Apr 15, 2004 | 11:15 AM
ssbowtie1's Avatar
Replace waterpump?
Well my car has 65k and the opti recently died, so I need to replace it. I am currently low on funds and would rather not replace the waterpump. How long do most people's waterpumps last? I'd hate to have it go out @ 70k and take out my new opti. Opinions?
Old Apr 15, 2004 | 11:21 AM
GreenDemon's Avatar
If you're not having overheating problems I wouldn't, too much money unless it's dead or about to die. Just make sure and get 2 new gaskets. I had my opti replaced and then a month later dug back in there to try and figure out what was wrong, didn't think to replace the gaskets. Not cool having steam come out from your hood every time you stop somewhere...
Old Apr 15, 2004 | 11:27 AM
ZDriver96's Avatar
mine went at 50k.. Make sure your water pump wasnt leaking out the weep hole which would spill on your opti and kill it.. Also can leak and cause corrosion on the plug that inserts into the opti which will make u have to buy a new opti harness and possibly a new opti if the corrosion is left there long enough..
I would change it. Cheep insurance. Plus you ahve to take it off anyways.
Old Apr 15, 2004 | 12:22 PM
JasonL's Avatar
LT1 water pumps only last about 60-80k. I would replace it now, unless you plan to kill your new opti too...
nikolt1
Feb 27, 2015 09:10 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
pologreen97z
Dec 2, 2014 10:42 AM
