replace rotor and cap ?
Old Feb 8, 2007 | 07:51 PM
dallas63's Avatar
i have a 1996 z28 with a 140,000 miles . i am doing a complete tuneup , should i replace the opti or just rotor and cap . also , what are the cheapest o2 sims that plug in . any help is appreciated . thanks
Old Feb 8, 2007 | 08:11 PM
VK's Avatar
VK
What are your plans for the car? Alot of performance upgrades? Are you going to be using any MSD ignition products? Do you have a decent budget or is it pretty tight?
Old Feb 8, 2007 | 08:23 PM
TKH_Z28's Avatar
I ordered a MSD rotor and cap kit for my lt1. I will be installing it tomorrow. Its a pain to install, the water pump and balancer have to come off for it to be installed i will repost the results tomorrow night or saturday when i get it put on....The price from Jegs was $177.22 shiped COD.
Old Feb 8, 2007 | 11:35 PM
jsetzer's Avatar
Is it bad? If not let it be, you will never have another one last as long as the original.
If you do change it, do the whole thing. Jason sells them for @ $240, if you just do the cap and rotor it will not last as long.
Old Feb 9, 2007 | 12:21 AM
1FstFormulaV8's Avatar
Replace the entire unit. If you go in and replace just the cap & rotor and that's not your fix. You're out another $200+. Plus you'll have the joy of doing all that work, again.
Old Feb 9, 2007 | 02:32 AM
2000GTP's Avatar
I would replace the opti as a whole assembly. As for the 02 sims, the plug-n-play ones usually run around 90 bucks for the pair. You can buy some cheapo ones off of ebay but you have to cut and splice them into the factory wiring harnesses.
Old Feb 9, 2007 | 03:28 AM
CustomSSI's Avatar
Ya if your there and have the money just replace the whole unit.. PM us if you want a smoking price on one :-D
Old Feb 9, 2007 | 04:32 PM
BrokeMofugga's Avatar
i replaced my cap and rotor on my opti with used parts none the less and havent had a prob yet.but i will be replacing my whole unit with a new one when money permits.but as for the install its not bad.i did mine at the max in about 2hrs.well anyways goodluck man.
Old Feb 9, 2007 | 08:09 PM
remaxracer45's Avatar
I replaced the cap and rotor and the optical part went within a year, moral of the story replace the whole thing and be done with it.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Jazsun
Dec 29, 2014 12:14 PM
ScottZ
Mar 3, 2004 01:34 PM
