replace piston question
Old Jun 19, 2007 | 01:16 PM
romoranger's Avatar
hey, i had a question about replacing the pistons on an lt1. a friend of mine wants to replace the pistons on his corvette (lt1 motor) with forged ones. if i am correct, the crank,pistons, and rods need to be taken out. the crank and the rods should be reconditioned, and then the rotating assembly (rods, crank, forged pistons) need to be balanced. new bearings everywhere, then assemble. i beleive this is correct.
I do not beleive that the pistons can just be "replaced" immediately without any machine work or balancing, but i could be wrong. i was hoping someone could inform me. thanks!
Old Jun 19, 2007 | 07:35 PM
MachinistOne's Avatar
You are correct.
Old Jun 19, 2007 | 07:41 PM
wrd1972's Avatar
Spot on.
Old Jun 19, 2007 | 08:50 PM
FlamingChicken's Avatar
shouldnt the bores at least be honed if not overbored? not sure how the new rings would seal without that
1963SS
Feb 6, 2015 10:05 AM
sscott
Jan 17, 2015 04:30 PM
Hurin
Dec 13, 2014 07:38 PM
Lederman1976
Nov 30, 2014 05:21 AM
