Is removing water pump driveshaft necessary for the horsepower?
Old Feb 16, 2008 | 07:05 PM
djm_e22's Avatar
Is it necessary to remove the water pump driveshaft in order to get the extra horsepower that I am trying to get with the electric water pump? Or can I just let it spin freely?
Old Feb 16, 2008 | 07:24 PM
'94 Bad A Z28's Avatar
What's the point in still having it there? Just remove it and plug the hole up. If you leave it there it is still "rotating mass" essentially.
Old Feb 16, 2008 | 09:16 PM
The point would be not having to do the extra work to remove it.
Old Feb 16, 2008 | 09:19 PM
ss.slp.ls1's Avatar
Leave it there, you've taken the mechanical energy needed to pump the water out of the equation, thats where the ~5 rwhp comes from. Removing the shaft isn't gonna affect much.
Old Feb 17, 2008 | 12:37 AM
Yeah I know, that's why I left mine in for about 3 years, lol.
Old Feb 17, 2008 | 10:36 AM
The Engineer's Avatar
The best option is to remove it, then you don't ever have to worry about an oil leak or the gears and bearing going bad.
I plugged the shaft hole with a NPT Allen socket plug.
WD
Old Feb 17, 2008 | 06:11 PM
Romero155's Avatar
And just in case you want to sell the car you can just put a stock waterpump on without having to tear down the timing cover again.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
pologreen97z
Dec 2, 2014 10:42 AM
