Distributor Seal
Old Feb 17, 2008 | 09:25 AM
tt1079's Avatar
Distributor Seal
NM, found what I needed doing Timing Cover seal as a search... sorry for the additional thread.
Edit Again: Got tool and it broke while trying to pull out the seal...
Old Feb 17, 2008 | 09:35 AM
Ken95Z28's Avatar
If you are not pulling the timing cover you will have to pry the old one out. Then you will have to put the new one in, it's not impossible to do this but installing the new seal while on the car is difficult. I have done it once before. If you decide to pull the timing cover you will have some difficulties of pulling the timing cover due to the pan gasket. If the pan gasket have never been replaced chances are its has some RTV on it, especially on the corners. You can stand a risk of tearing the rubber gasket. I would try first to install it on the car then if worst comes to worst pull the timing cover.
Good Luck,
Old Feb 17, 2008 | 10:12 AM
tt1079's Avatar
Thanks for the reply, I can't seem to get a good enough grip to pull out the old seal and now it's in pretty bad shape... I got a tool from harbor frieght and it broke pretty easily, any other suggestions I'm really not up for the challenge of pulling the timing cover if that's what is needed and now the seal is toast...
Old Feb 17, 2008 | 01:18 PM
Green96Z's Avatar
What kind of seal puller are you using? I used this tool and it was a breeze (had the cover off, but same principal):
http://www.amazon.com/gp/product/B0002SRCKG
Then just use a seal installer:
http://www.amazon.com/gp/product/B0002SRGFM
You might not have enough room though, because you have to line that seal up just right and give it some good whacks. I really recommend pulling the cover. But if you do, replace all 3 seals on there. You will need to drop the oil pan about an inch in front to remove it so you don't tear the pan gasket.
Old Feb 17, 2008 | 06:20 PM
tt1079's Avatar
Thanks for the comments, I was able to remove the old seal with the tool you showed from amazon, but then I couldn't get the new seal back in... finally I used old scrap 2 X 6 that was about 8 inches in length and placed it on top of the hub and gave it about 3 good solid hits (radiator still on car btw) and was able to get the seal on, so now I'm a bit futher... thanks again
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Sep 27, 2015 01:07 PM
autoxr166
Sep 25, 2015 04:21 PM
1995Blackz28
Jul 20, 2015 09:34 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
