Removing U bolt out from the master slave help!
Old Feb 8, 2005 | 11:41 AM
AlmostfastLT1's Avatar
I have a 94LT1 6speed. I am installing a whole master,slave unit. I am having trouble removing the u bolt on the firewall. There is a serated hole on one side of the u bolt studs and it is keeping it from backing out. What did you all do, the other stud on the u bolt will push right out but the other one will no buge.
Thanks Mark Tisdale
Old Feb 8, 2005 | 11:53 AM
Pasky's Avatar
Re: Removing U bolt out from the master slave help!
What I do, is either wiggle it, or go under the drivers side dash and punch it out gently.
Old Feb 8, 2005 | 11:54 AM
I have been taping it and it it not really moving.
Old Feb 8, 2005 | 11:55 AM
TW95Z's Avatar
On my 1995 there was a thin "washer" on that stud that I think they use at the factory to keep the U bolt from falling out during assembly. It's between the firewall and the metal bracket, so you have to loosen the bracket enough to get behind it. I was able to "unscrew" the washer off the stud using my fingernails.
Here's some pictures of my installation.
http://www.pharmacy.arizona.edu/staf...sterslave.html
Tim
Old Feb 8, 2005 | 11:56 AM
Pasky's Avatar
Not sure then, mine comes out really easy. Is there anything on a fourthgen blocking it? Just tap both sides and keep tapping them until it comes out. Just use a phillips screw driver and hammer.
Old Feb 8, 2005 | 12:06 PM
m0nk's Avatar
I seem to rember the same "washer" that TW95Z is talking about. That and I also had to kind of force mine out. It wasnt impossible thou.
Old Feb 8, 2005 | 12:59 PM
yea, I am going to try and unscrew that washer thanks guys.
Old Feb 8, 2005 | 02:59 PM
CamaroBoy96Z28's Avatar
That star washer got me too. Other than that, replacing the master or whole hydraulic setup is really easy.
Old Feb 9, 2005 | 09:54 AM
yea I got the washer removed, thanks guys.
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
BPS
9
Mar 5, 2015 10:51 PM
W7Z28
11
Jun 25, 2002 02:23 PM
