Removing the timing chain
Old Mar 13, 2004 | 06:46 PM
v7guy's Avatar
the timing chain I have is very tight and I'm having a lot of problems trying to get it off, I've never had this issue before, can someone reccomend a way to get the timing chain worked off the gears?
Old Mar 13, 2004 | 07:17 PM
joeSS97's Avatar
You have to remove the chain with the gears.
Old Mar 13, 2004 | 07:41 PM
v7guy's Avatar
you can't pull the crank gear without the chain off though, the cam gear bolts are out, I can get the cam gear to rock a little but I can't get it any where near far enough forward to pull off the dowel pin in the cam.
Old Mar 13, 2004 | 08:26 PM
With the cam gear bolts out and the dowel pin around the 3 or 9 o'clock position, you should be able to swing the cam gear downward on the dowel pin to give you slack.
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
