Removing Throttle Body
Old Jun 20, 2003 | 11:46 AM
kgkern01's Avatar
How do you remove the throttle body? I already have the coolant bypassed, I want to take it off to polish it up a little. Is it pretty straightforward just unclip the cables and sensors and unbolt, or is there something I need to look for or missing?
Old Jun 20, 2003 | 11:48 AM
Buttercup's Avatar
It's pretty straight forward. Remove the linkage for the throttle, cruise, TCS, unplug the vacuum lines and electrical connections and remove the 4-bolts. If it's never been off before you may have to give a few taps with a mallet to jar it loose. You will want to inspect the gaskets and decide whether you need new ones before reinstalling.
Old Jun 20, 2003 | 11:50 AM
indy500ss's Avatar
4 bolts and 5 minutes is all you need
Old Jun 20, 2003 | 12:24 PM
Bastardcat's Avatar
You will probably also need to buy a new gasket for it after you take it off--to be on the safe side.
Old Jun 20, 2003 | 12:34 PM
96 WS6's Avatar
You can reuse the gasket... I do at least with three different throttle bodies and it still seals perfectly.
Old Jun 20, 2003 | 12:38 PM
Bastardcat's Avatar
The only reason I suggested the new gasket was because mine tore when I removed the throttle body.
Old Jun 20, 2003 | 12:40 PM
Buttercup's Avatar
Which is why I suggested inspecting the gaskets before reinstalling
Old Jun 20, 2003 | 12:48 PM
Bastardcat's Avatar
Oops, didn't catch that.
Old Jun 20, 2003 | 09:03 PM
kgkern01's Avatar
Just polished my alternator today, will probably do the TB sometime this weekend, thanks for the info.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
