Removing T56
Old Jun 8, 2003 | 04:04 PM
irocbsa's Avatar
Removing T56
I'm trying to replace the clutch in my 94Z. I can't get the tranny separated from the block. Do you have to pull out the clutch fork? If so, how do I get it out? Thanks.
Old Jun 8, 2003 | 04:27 PM
You have to pull out on the clutch fork to disengage it or the tranny won't come out. Lots of people pulling trannies. This question seems to be asked every day.
Old Jun 8, 2003 | 04:43 PM
Wild1's Avatar
What type of clutch did you decide to go with? I should have replaced the pilot bearing on my swap and now it rattles like crazy. I'm afraid I may have toasted the input shaft on the tranny.
Old Jun 8, 2003 | 04:56 PM
Abdullah's Avatar
how to pull the clutch fork out? me too trying to take the T56 transmission out of my other 94 M6 Z28 and i couldn't.
Old Jun 8, 2003 | 04:58 PM
notstock4long's Avatar
there is a bolt in the middle of the clutch fork you have to take off. 9/16 I think. It is hard to get to, you have to take some other stuff off first I think.
Old Jun 8, 2003 | 05:11 PM
thewinner's Avatar
nah no need to remove bolts, just pull down hard on it. not like straight down, but grab the fork and pullit straight out towards the side of the tranny
Old Jun 8, 2003 | 09:29 PM
Abdullah's Avatar
thewinner, pull the fork like up side toward the trany or pull it out straight toward the car's body?
Old Jun 8, 2003 | 09:35 PM
Dave88LX's Avatar
Check out this directory for a bunch of pics for reference when I removed my clutch:
http://paradox.shacknet.nu/dave88lx/formula/clutch/
Pull it STRAIGHT out. YOu can pull that little housing off once you remove that little hydraulic thing. THen just pull straight out.
I had to FIGHT for a couple hours after that to get mine separated from the bell though, I think the alignment dowels were prety stuck to the holes...
Anywyas, here you can see how it pulls straight out:
http://paradox.shacknet.nu/dave88lx/...ranny-back.jpg
Clean version:
http://paradox.shacknet.nu/dave88lx/...nny-clean3.jpg
Here you can see how I have it pulled out as far as it will go. I actually didn't know that housing would come off at the time:
http://paradox.shacknet.nu/dave88lx/...n_tunnelLO.jpg
Old Jun 8, 2003 | 10:21 PM
Abdullah's Avatar
thanks Dave88LX for the pics, they were realy helpful.
Old Jun 8, 2003 | 10:35 PM
Dave88LX's Avatar
No problem man, good luck with it! I had a helluva time myself pulling my tranny out, because it was stuck to the bellhousing. Finally got it out while I was UNDER it, had to just take it from there and HOPE I could bench press it out Luckily it was only ~125 lbs.
Old Jun 8, 2003 | 10:43 PM
Z95m6's Avatar
also if it won't come off make sure you have the inspection plate off don't ask how i know that
Old Jun 8, 2003 | 11:05 PM
turbo_Z's Avatar
hey Dave,
is that old clutch a stock clutch? as far as you know has it ever been replaced before? reason im asking is the fingers on the pp look like that of an LT4 but i am assuming its and LT1 pp.
Old Jun 8, 2003 | 11:12 PM
Dave88LX's Avatar
The clutch was replace around ~50K miles, by a mechanic for the original owner. As far as I know it's a stock LT1 replacement, but I haven't seen an LT4 to compare. My SPEC PP looks the same though, even says the same thing stamped into it...Valeo...
http://paradox.shacknet.nu/dave88lx/...utch/spec2.jpg
Old Jun 8, 2003 | 11:19 PM
turbo_Z's Avatar
spec just paints and tags LT4 PPs.. they dont make their own.
Old Jun 8, 2003 | 11:26 PM
Dave88LX's Avatar
Yeah I didn't think that they made their own PP's...hmm...do the LT1 PP's say Valeo on them? What's the diff in an LT1 and LT4 PP? Anything we could tell?
