Removing Shaft from Waterpump?
Old Sep 10, 2005 | 07:23 PM
96trans am's Avatar
Im installing a Meziere. Ive done a few searches trying to find the right way to removie the impeller from the waterpump but havent had any luck. Looks like it needs to be driven out but I cant seem to get it. Does anyone know how this should be done? Thanks a lot. -Matt
Old Sep 10, 2005 | 07:31 PM
SnakeOiler's Avatar
Re: Removing Shaft from Waterpump?
I had a machine shop press mine out.
Old Sep 11, 2005 | 12:39 AM
gixxer92's Avatar
hammer and a piece of cold rolled steel, couple of hits and it was out.
Old Sep 11, 2005 | 09:57 AM
96trans am's Avatar
Which way does it come out? I would assume the blades and the shaft are one peice so it would come out that way. Also are you beating the sleave or just the shaft inside the sleave? Thanks. -Matt
Old Sep 11, 2005 | 02:54 PM
FIREHAWK #7's Avatar
helped one of my friends put his on.... we wacked on the shaft for 30 minutes with no luck. . . took it to a machine/head shop pressed it out in 5 minutes. . .spent like 5 dollars too
Victor Lamb
Aug 26, 2017 02:52 PM
Apr 16, 2015 09:57 AM
KYWes
Apr 15, 2015 07:28 PM
pologreen97z
Dec 2, 2014 10:42 AM
