Removing old motor mounts from clamshells
Old Aug 18, 2003 | 11:17 AM
Mullet Z28's Avatar
Sorry, couldn't find a direct answer using the search.
Anyway, the driver's side has rivets. Once they're drilled out, I assume that the clamshell will open right up.
However, on the passanger's side, the clamshell has no rivets. I've tried prying it open with a screwdrive with no luck. Any tips? Maybe I just need to pry with a little more force?
Old Aug 19, 2003 | 11:54 AM
Mullet Z28's Avatar
Help.
Old Aug 19, 2003 | 12:39 PM
Ken95Z28's Avatar
That's correct, once the rivets has been drilled out it will open up.
Are you sure it does not have rivets? Once it is drilled out is should open up so you can get the new one in. But either case it must open up in order of it to fit in.
Old Aug 19, 2003 | 05:51 PM
Mullet Z28's Avatar
Yep, not rivets.
Old Aug 19, 2003 | 06:01 PM
thewinner's Avatar
there are rivets in both sides. trust me
Drill em out or grind em off then use a chisel to pry them apart
HectorM52
Jul 30, 2017 11:46 AM
StansZ28
Feb 19, 2015 07:39 AM
Jason Short
Jan 19, 2015 06:34 PM
